droped somthing in the COOLANT HOUSING !!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2008, 09:37 PM   #1 (permalink)
flex1016's Avatar
View flex1016's Photo Gallery
3rd Generation droped somthing in the COOLANT HOUSING !!!!
hey guys! well today i went out to my car to check my radiator fluid when i took the radiator cap off the coolant housing the small ruber peace from the bottom of te cap fell inside the colant housing.. it fell deep inside were i cant rach it or even see it..what should i do to remove it, and is this bad ?
i was thinking maybe geting my wetvac and maybe sucking it out?
help me out here guys cuz im lost on this one
flex1016 is offline   Reply With Quote
Old 12-20-2008, 10:12 PM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
you could try flushing it out.
TheKevin is offline   Reply With Quote
Old 12-20-2008, 10:29 PM   #3 (permalink)
View toyomoho's Photo Gallery
How big of piece? Is it big enough not to be drawn down the coolant tubes of the radiator, if so it should stay in the top of the tank?
Old 12-20-2008, 11:00 PM   #4 (permalink)
flex1016's Avatar
its the small ruber gasket thats around the radiator cap the car is a 94 v6 camry the cap doesnt sit on the radiator is sits on the coolant housing.. the size of the gaskit is about the same size of a nikel
Old 12-21-2008, 01:32 AM   #5 (permalink)
The Connoisseur
CharmCityES's Avatar
if its that large, youd probably have to remove the radiator and drain the fluid out of the coolant hose fittings and hope the gasket comes out...thats about the only advice i can offer
The "Executive Sedan"
Old 12-21-2008, 01:52 AM   #6 (permalink)
just a nobody
Have seen those cap come apart and fall into the cooling system, however, never seen it cause any problem. It is after all a rubber piece, the worst case scenario, the rubber piece got stuff between the opening of the thermostat and it won't close all the way and it takes longer for you to warm up.
BTW, that cap has a larger piece of rubber seal than a nickel. If you are too concern, you can take the coolant housing off, but it could have gone somewhere else that you can't see.
N.E.O.
Old 12-21-2008, 04:51 AM   #7 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 12-21-2008, 09:02 AM   #8 (permalink)
flex1016's Avatar
ok guys thanks for all your help im going to try and just flush the system out and hope the peace comes out
