Sunroof leaking 1994 Toyota Camry Wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2008, 12:13 PM   #1 (permalink)
View rkpatt's Photo Gallery
I'm trying to address a sunroof leak (wet headliner in sunroof area ) in a relative's 1994 Toyota Camry wagon . It a appear to have the factory fixed glass sunroof . She mentioned that this problem occurred a few years ago and they blew something out with air . I have browsed a little here and have found that leaking inside the car might be are result of clogged sunroof roof drains /tubes . Where are the roof drains and tubes on this model and how to I access them ? Also,I was wondering if windshield sealer under the lip of the gasket would help ? - Thanks
rkpatt is offline   Reply With Quote
Old 12-21-2008, 12:27 PM   #2 (permalink)
just a nobody
The drain hoses, two in the front corners, and two in the back. The ones in the front you can see, the ones in the back you cannot, but they usually drain out behind the rear wheels. You can check it by using a hose to run some water around the outer edge of the opening, just watch to see if the water drains out.
Are there debris in the sunroof track?
N.E.O.
Old 12-21-2008, 12:30 PM   #3 (permalink)
View toyomoho's Photo Gallery
The sunroof has plastic tube drains behind each wheel well. This is what is blow out with air.
Old 12-21-2008, 03:09 PM   #4 (permalink)
Thanks for those replies . I blew out the front drains form the top . Then I blew out the hoses behind the wheel wells. I wiped out the debris / slime that I could get to (no musch there ) . I didn't have time to put water in the " internal gutter " for testing but will do so soon .
