I have recently upgraded from auto transmission to 5 speed manual. After a while, the ABS light went on and yes, the brakes are locking already. Codes 71 to 78 mean low voltage and incorrect voltage on all four wheels. I have not touched the rear wheels during the conversion or the abs system. Is it possible that there's an open circuit in one of the abs wheel speed sensors?
1993 Toyota Cresta Tourer S JZX90
1988 Toyota Mark II GX71
1999 Subaru Outback 5-speed
2000 Toyota Mark II IR-V
2003 Subaru Legacy BP5 2.0R
How did you pull the codes? Those codes, I think, are for the speed sensor input test. Clear the codes and see if they reset.
N.E.O.
You're right, that's for the speed sensor diagnostic test. I found a main loose ground cable underneath the air filter box, connected it and those codes did not appear again. I redid the Tc, E1 diagnostic check and I had ABS trouble code 32 which is: Left Front Signal Malfunction. I'm going to have a look at the sensor tomorrow. I think I may have greased the area quite a lot before I put the CV in.
Does the gen 3.5 have sensor rings (that goes with the CV) for the ABS wheel speed sensors? I don't remember pulling one out.
Sorry to recover the old thread, but I have the code 71 after Ts-E test as well. What was the culprit after all?
ABS Code 71 means that the right front speed sensor is getting insufficient voltage. When I had the code I just checked for a loose grounding around the engine bay. After reinstalling a loose ground wire, I reset the ABS and the code's gone.
The Following User Says Thank You to 2win2rbo For This Useful Post:
Thx! And resetting ABS computer is just disconnecting/connecting back the big ABS connector?
There's a better way to do that.
You can
1) put a jumper wire on Tc and E1 on DLC1;
2) remove the short pin (from DLC1 as well);
3) Turn the ignition switch on;
4) depress the brake pedal 8 or more times within 3 seconds;
5) check that you have the normal code or that the codes are erased; and
6) put the short pin back.
You can
Is step 4 correct as written? Seems awfully fast to get through 8 cycles.
Yes it has to be awfully fast.
But what exactly does this reset? I don't have ABS code (I mean, ABS light is not ON all the time, I have code 71 only after doing Ts-E test; but it is not stored in ABS ECU, I think). So, is the reset still necessary?
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
-------------------------------------------------- FOR SALE, Sedan/Wagon parts
