Lights Dim while on Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2008, 05:34 PM   #1 (permalink)
View NYC_99Camry's Photo Gallery
Hey guys...quick questions. i have a 99 camry with approx. 95K miles. recently, while my camry is idling, all the lights in my car dims. and when i step on the gas, it becomes bright again. also, my power window and wipers becomes slow too when all my lights become dim. any ideas what it is causing this? at first i thought it would be the Intake Valve, but i recently cleaned with a Seafoam Intake cleaner....about 3 months ago. i was thinking it might be the battery or the alternator that is about to fail or something. please help...
NYC_99Camry is offline   Reply With Quote
Old 12-21-2008, 06:22 PM   #2 (permalink)
View toyomoho's Photo Gallery
What is the idle speed. Should be around 700 rpm.
Below 1500 rpm the alt produces less currant and the battery starts picking up the load.
Does the car have a high current stereo amp, etc?
With the engine off are the lights still dim, do the windows still drag? Don't put too much load when testing such as the heater blower, etc.
The battery could be dieing.
Old 12-21-2008, 07:00 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
alternator? ive had a similar problem on another vehicle and it was not charging the battery properly so at low idle it was dimming.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-22-2008, 12:02 AM   #4 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
Yea the alt is probably dying. You can get a little tester to see if it really is the problem, but be ready to replace the alt.
Check ebay good deals
If its a 4cyl, its an easy repair
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 12-22-2008, 01:09 AM   #5 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
The original battery in my '00 Camry finally died last month at 96K miles. My symptoms were similar to what you describe for awhile, then it finally would not hold a charge and failed to start.
Before you just go buy a battery, do check the battery, alternator (belt), connections, especially your battery terminals to make sure they are clean.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 12-22-2008, 05:20 AM   #6 (permalink)
thanks all. i'll probably go to the autozone tomorrow and check it out. also, i noticed there are two kinds of alternators. the brand new ones and the rebuilt ones. which is better?
