from clunking to squeaking in the back - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2008, 08:20 PM   #1 (permalink)
Newbie
View 94cylcamry's Photo Gallery
Hey all,
94 Camry LE, there have been clunking sounds and things coming from the back of the car for awhile now, but it has never really bothered me because I usually have the music up pretty loud. However I was driving with no music today, and I noticed that the problem has gone from just clunking to a sort of...squeaking...creaking..."SOME LUBE WOULD BE AWESOME"...sound. This happens when I'm going over bumps, anything that causes the car to bounce even the slightest bit produces some sound from the back.
What should I be checking? I read that sway bar bushings could cause something to squeak or clunk but.........does the Camry come stock with a rear sway bar? I thought it did, but I only see two rods coming down and connecting to that area, no bar that goes across. So I'm a bit confused.
Also, the struts aren't exactly recent, but they aren't the originals either, and the car doesn't bounce excessively or anything so I don't think the struts themselves are the problems. Maybe the strut mounts? I hope not, those are a little bit...ridiculously expensive.
Thanks!
1994 Camry LE 5SFE
160,000 miles[12/2/08]
94cylcamry is offline   Reply With Quote
Old 12-21-2008, 08:33 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Rear mounts probably broken and sway bar bushings dryed and desintigrating.
5 Lug Corolla WHAT?
Old 12-21-2008, 08:36 PM   #3 (permalink)
Newbie
Splendid. Can I visually confirm that without tearing the back apart?
1994 Camry LE 5SFE
Old 12-21-2008, 08:45 PM   #4 (permalink)
Dark Emrald 92''s Avatar
View Dark Emrald 92''s Photo Gallery
i have jad the same problem, but like u i cant here it over the music, but now that i now its not such a expensive fix (i have acces to lifts and tools cuz im currently attending an auto tech school progam so i can do it myself) i might actually take care of it. althought it could be really expensive
Dark Emrald 92' is offline   Reply With Quote
Old 12-21-2008, 09:14 PM   #5 (permalink)
View 1996camry's Photo Gallery
i have the same problem noise when go over the small hold or go up the hill...
my problem was the sway bar bushings (black rubber ) that caused the noise...replaced both bushings on rear then the problem (noise) went away...you can get the rubber black bushing from dealer... i got both bushing for 30 bucks..from dealer... my 96 camrry le 140k miles...
1996camry is offline   Reply With Quote
Old 12-22-2008, 05:24 AM   #6 (permalink)
Newbie
$30 bucks isn't bad...I'll have to look into that.
1994 Camry LE 5SFE
