tail light replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2008, 08:56 PM   #1 (permalink)
hav
View hav's Photo Gallery
4th Generation tail light replacement
Hi,
I have a 1999 Camry. Both my taillights (904) are not working. The brake lights 3157 are working fine. I checked the bulbs. they are fine. What else should i check. The indicator on my dash has started.
Thanks
hav is offline   Reply With Quote
Old 12-21-2008, 11:51 PM   #2 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
Did you try the relays? In the engine bay next to the battery. Oh and the fuses.
Worst could be a bad switch.
Try the fuse, then relay then switch. Just use a test light.
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 12-22-2008, 02:48 AM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Check the wiring harness near the trunk hinge...
BamZipPow is online now   Reply With Quote
Old 12-22-2008, 05:14 PM   #4 (permalink)
Gameroom cash: $303255
^ What BamZipPow said. Open up the loom of wires near the driver's side trunk hinge and check for frayed or broken wires in there. Note the color of the wires leading to the tails lights and pay particular attention to them. The wires in that loom have a tendancy to fray and break, due to all the flexing they are exposed to as the trunk is constantly opened and closed over the years.
Mike
Old 12-28-2008, 10:05 PM   #5 (permalink)
hav
Thanks guys! the problem was exactly what Mike said. The wires were broken onside the trunks ducting on the driver's side further down from the hinge. Too bad I read the post after I got it fixed from the mechanic.
