Outside Handle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2008, 10:01 PM   #1 (permalink)
Camry LE V6 2001
View REDSOXTICKET's Photo Gallery
Outside Handle
The weather frozed my drivers side handle and with little effort it broke when attempting to open the door. I'll need to order a color matching handle and follow the instructions and advice posted in this forum. This will be at a later time but for know I have a temporary fix idea that I want to run by you.
The handle broke off clean that is to say the plastic piece is flat with no jagged plastic (just a little bit of jag plastic). I have the idea of bonding the handle back together with two part quick drying epoxy. I will lift the handle that is attached to the door and place a wooden block under it so that the epoxy will almost be horizontal in the event it were to drip.
I need your feedback, advise, experience and opinions.
If this works I may hold off for a warmer day or even forget about it.
THX
REDSOXTICKET is offline   Reply With Quote
Old 12-21-2008, 10:36 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349353
View BMR's Photo Gallery
I used an epoxy called PC7 to glue mine back together. It's really thick so dripping isn't a problem. And it cures very slowly, so you can push it around quite a bit when it's half-cured to form a nice fillet in the corners.
BMR is online now   Reply With Quote
