Auto gear select light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2008, 10:45 AM   #1 (permalink)
David48's Avatar
View David48's Photo Gallery
The gear select light on my 96 camry isn't coming on. Does anyone know why? Sorry for not having too many details. It's located on the instrument cluster and runs verticly through the center.
^Click on it to see it un-edited.^ Not so flattering, is it.
David48 is offline   Reply With Quote
Old 12-22-2008, 10:53 AM   #2 (permalink)
just a nobody
All of them or just one? Probably just a bulb if only one of them is not working.
N.E.O.
Old 12-22-2008, 06:47 PM   #3 (permalink)
David48's Avatar
None of them come on. But everything else on the cluster works just find.
Old 12-22-2008, 08:16 PM   #4 (permalink)
just a nobody
There are a few possibilities, the connector to the instrument cluster is not connected properly, or the P/N switch at the transmission, or the wiring harness. Have you notice anything else that is not working with the transmission, the instrument cluster? Any check engine light or starting problem?
Didn't you repair or replace the engine recently? I would start from the transmission then.
N.E.O.
Old 12-23-2008, 12:22 AM   #5 (permalink)
View djb2's Photo Gallery
Have you spilled coffee into the center console shift lever recently? Or disassembled anything in that area? If so, the problem is likely the switch attached to the shift lever. Remove the trim around the lever assembly to check for obvious problems.
djb2 is offline   Reply With Quote
Old 12-23-2008, 08:46 PM   #6 (permalink)
David48's Avatar
Well it starts just fine. I doubt its anything with the transmission. And come to think about it, I remember cleaning up some dry sticky stuff that I assume was spilled soda/cola from the center console just in front of the shifter. Maybe that has something to do with it? I'm going to check it out tommorow, I have to replace the center console that surrounds the shifter anyway, so I'm probably going to open it tommorow and see if anything is wrong, then I'm going to check behind the instrument cluster to check for any un-plugged wires. Thanks for the suggestions.
Old 12-23-2008, 09:04 PM   #7 (permalink)
just a nobody
I was referring to the Park/Neutral switch at the front of the transmission, not the transmission itself, that is where the signal for the indicator lights come from.
N.E.O.
Old 12-24-2008, 09:21 AM   #8 (permalink)
David48's Avatar
Well, I started opening the console a few minutes ago. I didn't see anything abnormal in there. I was in the process of removing the instrument cluster, but I got kind of stuck with the panel that goes all around to the radio and vents in the center. I'm just waiting for my dad to get back from somewhere to see if he can get it off. I already took off the screws, but its stuck on something at the far right side. I'm just paranoid that I'm going to brake something in there.
Old 12-24-2008, 10:32 AM   #9 (permalink)
View donbryce's Photo Gallery
I've only had my '96 Camry for less than 2 months. When I got it, I noticed that the only light that doesn't come on in the instrument cluster is the 'D' light. All the others work. The seller told me that was normal. Is it?
donbryce is offline   Reply With Quote
Old 12-24-2008, 11:58 AM   #10 (permalink)
just a nobody
No! It should have 'P', 'R', 'N', 'D', '2', '1', I think, and 'OD', and 'Power'.
N.E.O.
Old 12-24-2008, 12:39 PM   #11 (permalink)
Newbie
View 94cylcamry's Photo Gallery
Eh, my D light doesn't come on either. Apparently that's pretty common. Just be happy the R light comes on...if that doesn't come on, neither do your reverse lights. Mines been sticky lately...
1994 Camry LE 5SFE
160,000 miles[12/2/08]
94cylcamry is offline   Reply With Quote
Old 12-24-2008, 03:37 PM   #12 (permalink)
just a nobody
Those bulbs can be replaced individually; however, the socket and the bulb is one single unit, and it cost more that a regulator bulb.
N.E.O.
Old 12-27-2008, 11:54 AM   #13 (permalink)
David48's Avatar
Now I feel like an idiot. I got the cluster out, and were I thought the light comes on, there's NOTHING!! I assume my camry was a lower trim level? I'm pretty sure I've seen the select light there on other gen3s. I guess it was an option on higher trim level camrys??? Well, problem solved. And now I get to clean the cluster!
Old 12-27-2008, 12:10 PM   #14 (permalink)
just a nobody
Been there myself quite a few times, so don't feel bad, and WELCOME to the club!
N.E.O.
