foggy windows - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2008, 05:20 PM   #1 (permalink)
View ricelake's Photo Gallery
foggy windows
I recently purchased 97 2.2 for son it seems to have a lot of moisture inside windows on cold day running defrost with ac mode helps. I want to ck ac drain to make sure water would drain,any tips on location of drain inside car or outside on firewall point me in the right spot thanks in advance and merry christmas to all
ricelake is offline   Reply With Quote
Old 12-24-2008, 06:18 PM   #2 (permalink)
Gameroom cash: $303255
The A/C drain should be in the engine comparment just forward of the firewall on the passenger side.
I would also suggest you make sure the air source switch is set midway between recirculate and outside air. If that doesn't work try it totally on outside air. Another possibility is a leaky heater core. Is there a sweet smell in the car?
Mike
Old 12-25-2008, 09:45 PM   #3 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
3rd Generation
if u still havnt gotten it fixed then no worrys tho. My camry always fogs up like that but then i just crack the front left window and the rear right window. or oposite. only takes a few sec to a few min to solve the prob.
It cycles the air quicker imo. then when it goes away close windows and enjoy! if it does it again then crack again lmao
Spitfire is offline   Reply With Quote
Old 12-26-2008, 01:56 PM   #4 (permalink)
View lenjack's Photo Gallery
If you get on the ground and look underneath, with your head just in front of the passenger side front wheel, you can see the drain. Mine clog about once a year.
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
