wiring mystery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-26-2008, 04:01 PM   #1 (permalink)
View PeterSGHS's Photo Gallery
wiring mystery
So I'm almost done with my motor and tranny swap (blown head gasket and slipping tranny) but there are a couple of wires that I can't find the connector to. One branches off the engine wiring harness between the engine and the heat shield. THe other dangles near the oil filter in front. Could any of you tell me where these connect or be so kind to check your camry to help me solve this mystery? Thanks a bunch!
Under the intake manifold between engine and heat shield.
The Connector you see towards the right is the transaxle.
Picture of the connector (2 wire)
Here is the mystery in front:
The one was folded, I believe it's also two wires.
I'm not sure where it was tucked when i disconnected it.
There it is dangling (notice the bends) Not sure where it goes.
Thanks again.
PeterSGHS is offline   Reply With Quote
Old 12-26-2008, 04:13 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
What year is this? Can you read the 5-digit number (1xxxx) off the connectors?
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 12-26-2008, 04:54 PM   #3 (permalink)
Oh, I forgot to add that detail: it's a 1993 Camry LE V6: 3vz-FE and A540 tranny... let me check to see if there's a 5 digit code. I'll clean it off
Edit: None.. no code on the connectors
Old 12-26-2008, 05:34 PM   #4 (permalink)
View toyomoho's Photo Gallery
Does the plug go to the speed sensor shown in photo 2.
