Just an update on my repair and current issues. Sorry for the long note but I would appreciate any advice.
I put things back together last night. I replaced the cam/crank seals, both idler pulleys, water pump, thermostat and the shaft seal and o-ring in the oil pump as well as the timing belt. I passed on the oil pump to block seal, I wasn't sure it was leaking. I also pulled the distributor and replaced the o-ring.
I believe the timing belt alignment went ok, but... I followed the manual supplemented with one of the DIY threads on the subject here. The TDC setting went ok, i think, the marks lined up and I rotated thru 720 deg twice to double check. The 0 mark on my TB cover is damaged but I can see the zero and guesstimated that the mark would be in-line with it. There was something in the manual about
(d) w/ Green Tension Spring:
Slowly turn the crankshaft pulley 1 and 7/8 revolu–
tions, and align its groove with the mark at 45 BTDC
(for No.1 cylinder) of the No.1 timing belt cover.
NOTICE: Always turn the crankshaft clockwise.
I didn't do this, wasn't sure if this was for a specific model or something my tension spring isn't green--is this something i need to do?
So its back together and is running pretty rough; I also hear a little valve clatter but that may have been there before? I haven't adjusted the ignition timing after changing the distributor o-ring.
In fairness it was running rough before I started the repair but ran well before the break down. The water pump had gone out on the highway and there was very little coolant left in the engine; I'm worried that there was some overheating damage. The thermostat went hot and the car stalled due to a blown ignition fuse. I replaced the fuse and it started but was running rough. At that point, I dove into the tB/water pump replacement...figuring that losing the pump may have screwed up the timing.
So here I am...I'd appreciate any advice on next steps---should I take the top TB cover back off and re-check the alignment. How crucial and or likely is it that the ignition timing is my issue following the distributor o-ring replacement.
Thanks your advice is appreciated.
