Sure, jack the car up on stands and start it up cold. Then go under with a flashlight and look for exhaust from the flex pipe area. Use a mirror if necessary to look at the top of the pipe, but I doubt it will be necessary if you start it up cold. It should be pouring out of there.
If you ran up on a curb or hit something underneath, the flex pipe can get damaged if your exhaust downpipe takes a direct hit. Or, I guess it can just wear out, or if mishandled during repairs, it can get damaged.
$200 is not that unreasonable. $250-$300 will probably get you a brand new one though? You may be able to find someone to weld a new flex piece in for $150, but not much cheaper.
dave mc
