Originally Posted by vfr.moua
Hi,
First time posting. I recently change the timing belt on my 98 camry I4 and noticed that the timing belt was a bit loose between the campulley and water pump with the old timing belt. I installed the new timing belt with new idler bearing, new tensioner and new tensioner spring with the campulley was dead on TDC and the crankpulley was on TDC. My problem is that the new timing belt is still a bit loose between the campulley and the water pump as well. I tried a few times and made sure that as I loop the timing belt it was as tight as it could be from the crank pulley to the water pump but still get the "loose" portion. Is this normal for the camry timing belt or did I do something wrong? How tight should the timing belt be? Thanks for any help you can get.
There should be moderate tension (ie. no sag) in the timing belt between the cam shaft pulley and crankshaft pulley on the side of the timing belt facing the front of the vehicle (ie. on the waterpump side), before you tension the belt with the tensioner.
When you first slide the belt onto the pulleys, it is inevitable that there is some slack on the side of the timing belt facing the front of the vehicle. You simply need to rotate the cam pulley CCW slightly to take out this slack, so that the timing belt is tight on the front side, and then tension the belt with the spring loaded tensioner.
