HELP! My clutch gets stuck when pressed, 96 camry. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2008, 10:40 AM   #1 (permalink)
View Fabito's Photo Gallery
3rd Generation HELP! My clutch gets stuck when pressed, 96 camry.
Hello,
1996 Camry, 2.2l, 4 cyl. Manual.
With the engine off:
Pedal goes in and returs, most times returns just half way. I put in all 5 gears including reverse and it seems to work fine, with just the problem of returning half way.
With the engine on:
Idling the engine and just pressing the pedal:it goes down and back but just half way ( so I think its the spring in the padal)
However, when I put it in gear and keep the clutch down for more than 3 seconds giving it some gas ( as if I was backing up of a busy mall parking lot space very slowly) the pedal stays down and the engine starts to rumble as if I was going really slow and on gear, since the clutch is already all the way down, all I can do is shut off the engine.
I have bleed the clutch line and replaces the slave(release) cylinder, and I still have this problemo.
Any ideas? Has this happened to anyone? How did they fix it?
Thanks!
Fabito is offline   Reply With Quote
Old 12-31-2008, 01:49 PM   #2 (permalink)
toyota = cool
tacomonkey69's Avatar
View tacomonkey69's Photo Gallery
had the same problem. went to the dealership and they fixed it when i had my oil changed.
1997 Toyota Camry V6 5-Speed
1995 Lexus SC400...big plans for this one
tacomonkey69 is offline   Reply With Quote
Old 12-31-2008, 04:55 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $764710
View BamZipPow's Photo Gallery
Have you thought about rebuilding/replacing the clutch master cylinder?
BamZipPow is offline   Reply With Quote
Old 12-31-2008, 07:54 PM   #4 (permalink)
View toyomoho's Photo Gallery
The slave or master cylinder may be leaking. When the pedal is down fluid leaks from one side of a piston to the other the result is the clutch starts to release and engage the transmission.
Old 12-31-2008, 09:01 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359260
iTrader Score: 13 reviews
sounds like the master cylinder then since you've replaced the slave.
replace that and you should be good. There are only so many components to the hydraulic system.
HaHa
Old 01-01-2009, 09:41 AM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $231380
iTrader Score: 37 reviews
View Knailgun's Photo Gallery
my thoughts exactly, best of all, it is a cheaper fix....about $90 all said and done
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 01-01-2009, 01:22 PM   #7 (permalink)
Was it a quick fix? or was it a: "you have to replace this, that, theses and it costs$ $$$$$$$$$$$$$$$$?
Old 01-01-2009, 05:14 PM   #8 (permalink)
just a nobody
Usually on a clutch hydraulic system, when one part of it fails the other part may not be far behind, so replacing both is the way to go to save from the headache having to deal with it again.
N.E.O.
