'93 Camry running on 5 cylinders, need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2008, 08:37 PM   #1 (permalink)
View jal570's Photo Gallery
I have a 1993 Camry with a 3VZFE V6. The engine has new plugs, wires, cap and rotor. One of the cylinders is not firing. I am fairly positive that the compression chamber is getting air, and spark. When I put my ear against a screwdriver on the fuel injector of the cylinder described, I hear a clicking noise like a functioning injector.
Does anyone know why this cylinder wouldn't be firing?
Any help is much appreciated!
jal570 is offline   Reply With Quote
Old 01-01-2009, 06:58 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
How do you know? I'd try to locate which cylinder. Pull plug wires one at a time and see if misfire gets worse or stays the same. On the one where it stays the same, that's the missing cylinder. Pull plug and ground on engine with plug wire attached and see if you're getting spark.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-01-2009, 11:25 AM   #3 (permalink)
I know which cylinder is misfiring because I started by doing exactly what you said. I'm getting spark at the plug for the cylinder that wont fire. So, I'm sure that the cylinder that wont fire is getting spark.
Old 01-01-2009, 01:37 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
spark plug wet with fuel?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-02-2009, 06:07 PM   #5 (permalink)
somewhat wet. not drenched like one would think
Old 01-02-2009, 08:01 PM   #6 (permalink)
View toyomoho's Photo Gallery
Do a compression test on the bad cylinder in case you have very low compression.
