LEDs for DRL ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2008, 11:55 PM   #1 (permalink)
View zwfly's Photo Gallery
Canada LEDs for DRL ?
If LED working voltage is 9-14V, can I use it as my DRL?
I guess canadian DRL is 6v for 9005, right?
http://www.superbrightleds.com/specs/H3_11-WHP.htm
Thank you and happy new year
zwfly is offline   Reply With Quote
Old 01-01-2009, 01:16 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
I don't know about 9005, but on my Corolla DRL runs my H4 low filament and feeds 9V. But with LEDs not nearly as bright as any filament headlight bulb, I would separate the DRL circuit from the headlight bulb and wire it so that it runs LED at full voltage. 9V ought to be enough to energize a relay or a TIP12x transistor circuit. This is better done with a separate LED unit than dropping in a 9005 LED bulb. Some times you do want your high beam.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 01-01-2009, 01:35 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The DRL circuit can be taken off the DRL resistor which will isolate the DRL to switch the relay you add in. Any 30A relay (Bosch, hella, omron, etc.) I have used 7.2V dc to switch the relay without problems in small projects.
When you disconnect the DRL resistor, the high beam still works when you switch them on at the control stalk.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
