Usually, this is also indicative of dirty window winding mechanisms and/or a window motor that is about to die. The window mechanisms, even though they are inside the doors, are still exposed to dirt and water. They tend to get clogged with dirt and begin binding (after many years)....and this often leads to the window motors burning out. If you have one or more windows (the driver's window usually goes first) that seem slower than normal....then it is likely getting ready to die.
There is no fix for this, IF the problem is, in fact, binding window mechanisms....short of disassembling the doors and cleaning/ lubing parts ....or replacing them.
Any excess force required from the motors (to raise or lower the windows), puts a great strain on the motors....and they will burn out, if this continues. It is not normal, just because of the temperature, (unless MANY degrees below zero), for the windows to not work as well as in warmer conditions. Of course, ice and/or snow, blocking the normal operation of the windows, is another matter - and one which can easily lead to burned out window motors, if you try to operate them while blocked.
