93 Camry Dimming dash lights etc. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2009, 07:40 PM   #1 (permalink)
View LUVLEXUS101's Photo Gallery
3rd Generation 93 Camry Dimming dash lights etc.
Is it normal for when my car is idling at say about 800 rpm, and I close my power windows up or anything like that all the dash lights and even the headlights somewhat as well. If I do more than one window at once it gets even dimmer. If I'm simply idling and I rev it up to say 1000 or 1200, everything gets a bit brighter. Any Ideas? I believe the alternator was changed a couple years back. On the other hand, is this normal?
LUVLEXUS101 is offline   Reply With Quote
Old 01-01-2009, 08:19 PM   #2 (permalink)
View cntmn8td2006's Photo Gallery
I have replaced my car battery about 5 months ago, and I have a similar situation. While I use my power windows I do notice my dash lights and my head lights dim slightly. Other than this I do not notice anything electronically wrong with my car. I would recommend that you clean the heads of your battery, and maybe somehow check to see if your battery needs to be changed.
cntmn8td2006 is offline   Reply With Quote
Old 01-01-2009, 08:43 PM   #3 (permalink)
I'll try cleaning the heads of the battery, Im sure its not the actual battery, I get it replaced every 2 years at Sears using the warranty
Old 01-01-2009, 11:49 PM   #4 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
It;s normal, not an issue. Happened on my old '92 5SFE, happenes on my dad's '96 5SFE wagon, and happenes on my '96 1MZ-FE.
5 Lug Corolla WHAT?
Old 01-02-2009, 12:07 AM   #5 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
^ Other than cleaning the battery posts, is there any other things to look into? My dash lights dim pretty bad. Replace grounds? Get a thicker gauge wire for the ground?
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
