E-Brake Cable '99 CE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2009, 01:15 PM   #1 (permalink)
Stock Nazi(ish)
gregorv's Avatar
View gregorv's Photo Gallery
Canada E-Brake Cable '99 CE
I did some searching and couldn't find an answer in a previously discussed topic about the problem I am facing.
I am currently needing to replace the drivers side e-brake cable, and shoes on both sides for my Camry. It is the V6 CE model with disc brakes- Japanese built. I have the rotors off and the center console taken out so that I have access to both ends of the cable.
It looks as though the rear cable (the one I am replacing) joins with the front cable on the other side of a steel barrier. Is there anyway to remove this barrier? I couldn't seem to find a way to remove it so that I could take out the old cable and install the new one.
Your help is greatly appreciated.
1999 Camry, 3 litre V6 Auto- 330 000 km
gregorv is offline   Reply With Quote
Old 01-03-2009, 07:07 PM   #2 (permalink)
Stock Nazi(ish)
gregorv's Avatar
bump
Old 01-03-2009, 08:49 PM   #3 (permalink)
View toyomoho's Photo Gallery
Take a look at the photo of a replacement cable, this may help you figure out how it comes off.
http://cpwstore.carpartswholesale.co...+cable+bc95781
Old 01-03-2009, 09:27 PM   #4 (permalink)
Stock Nazi(ish)
gregorv's Avatar
I already have the new cable bought and the old one half off. I just can't find out how to get the barrier off which blocks the connection of the two cables. Thanks for the help though.
Old 01-04-2009, 01:07 AM   #5 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
It's a heat shield held on by 3 nuts.
5 Lug Corolla WHAT?
Old 01-04-2009, 08:34 AM   #6 (permalink)
Stock Nazi(ish)
gregorv's Avatar
Smile
Thanks!
Old 01-04-2009, 07:20 PM   #7 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
Greg - If you don't mind me asking, what problem are you fixing by replacing the parking brake cable and how much did the replacement cable cost? Were you able to get an aftermarket cable?
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
Old 01-04-2009, 07:52 PM   #8 (permalink)
Stock Nazi(ish)
gregorv's Avatar
The drivers side rear wheel had locked up while the car was in my driveway (sitting for a week without moving). The cable had seized so I decided I would replace it along with all the parking brake shoes on both sides. I got the cable for $45 at a local shop and the shoes for $13.99 each at the same place.
Edit-
The parking brake was engaged for the whole week while the car was sitting.
Old 01-05-2009, 09:38 AM   #9 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The parking brake shoes for $14 ???
Which supplier? I bought them from dealer for $38 each!!
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-05-2009, 03:03 PM   #10 (permalink)
Stock Nazi(ish)
gregorv's Avatar
I bought them at a place called Ferguson's. I will check the aftermarket brand name when I get home.
Old 01-06-2009, 04:52 PM   #11 (permalink)
Stock Nazi(ish)
gregorv's Avatar
The shoes were made by Brake 1 and the cable was made by Absco.
