a/c problem in wet weather - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2009, 09:24 AM   #1 (permalink)
cmryhldr's Avatar
View cmryhldr's Photo Gallery
4th Generation a/c problem in wet weather
My 01 Camry 4 cyl. air conditioner green light in the switch will blink and go out if I run through standing water during a heavy rain. The compressor actually quits working. Something is getting wet that shouldn't. Any suggestions on stopping this?
cmryhldr is offline   Reply With Quote
Old 01-04-2009, 10:29 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Pressure switch mounted on receiver/dryer just behind grille, compressor belt slipping causing compressor rpm sensor to show problem, compressor clutch slipping when wet (adjustment). Just some possibles.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-04-2009, 10:38 AM   #3 (permalink)
cmryhldr's Avatar
4th Generation pressure switch on reciever/dryer
It could very well be the press switch. I think I'll put some kind of protective cover around it and wait for the next big rain to come. Thanks! Guess I should also tighten the a/c belt a little also.
Old 01-04-2009, 12:13 PM   #4 (permalink)
Gameroom cash: $303255
I used to have this exact problem with an 86 Camry. I always assumed it was just the belt slipping when it got excesively wet. When it happened I would just pull over when it was safe and simply shut off and restart the car. The A/C then worked fine. I never bothered to fix it since this seemed like an easy work-around.
Mike
