transmission problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2009, 12:48 PM   #1 (permalink)
View stevelobello's Photo Gallery
i have a 96 camry 4cyl. the check engine light is on and i had it diagnosed and they said it was the shift selonoid. i have two questions. first, will the shift selonoid affect my mpg, i am currently getting 18 mpg. second question is can i change the shift selonoid without droping the trans?
stevelobello is offline   Reply With Quote
Old 01-04-2009, 02:09 PM   #2 (permalink)
View toyomoho's Photo Gallery
The trans has about 4 shift solenoids, do you know which one?
Might be the solenoid SL (also called E) that controls torque converter lockup. If the torque converter does not lock up the engine RPM will be higher then normal about speeds of about 40 MPH. This could cause a drop in MPG.
You can remove, clean, test, replace solenoids by dropping the trans pan.
