Gen 3 cracked upper air duct repaired - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2009, 12:51 PM   #1 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
It pays to inspect your engine bay at least once a month. There was this noise coming from the bay, could not pin point it. Turns out I had a cracked upper air duct. See picture before and after repair.
04 SC430 05 RX330
96 Camry LE T-boned Oct. 09 RIP
mandyfig is offline   Reply With Quote
Old 01-04-2009, 01:13 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I have the same thing on my car right now. I'm hoping to get this turbo project started soon so I can replace that piping. No noise coming from my engine bay though
RichieRichJP is offline   Reply With Quote
Old 01-04-2009, 02:01 PM   #3 (permalink)
View toyomoho's Photo Gallery
Had the same problem. Suggest you check the repair often, the shaking engine tends to cause the repair to break. Ended up replacing the duct after numerous attempts to repair it.
Old 01-04-2009, 02:05 PM   #4 (permalink)
View ARIST0's Photo Gallery
Good reason to save for a ram air kit.
ARIST0 is offline   Reply With Quote
Old 01-04-2009, 04:18 PM   #5 (permalink)
View LUVLEXUS101's Photo Gallery
3rd Generation
How does that air duct work? Does it provide a vacuum or like air pressure to the engine? I thought it was like skipping the entire air intake so i took it off and tried to start the engine which didnt work? Was that a bad idea?
LUVLEXUS101 is offline   Reply With Quote
Old 01-04-2009, 04:46 PM   #6 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
If you remove that, you effectively are removing the air coming from the MAF which is what the other end of that pipe connects to,
cykaaro is offline   Reply With Quote
Old 01-04-2009, 07:57 PM   #7 (permalink)
mandyfig's Avatar
I installed a short ram intake and did not like it, I did not tighten the clamps, in time it loosend and the crack happened. I probably have too much vibration, I suspect my rear mount it kaput. I replaced the dogbone and front mounts last year.
04 SC430 05 RX330
Old 01-05-2009, 03:25 PM   #8 (permalink)
mandyfig's Avatar
Where did you buy the air duct and how much did it cost?
Thanks.
04 SC430 05 RX330
