Discussion: EGR Delete - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2009, 10:52 PM   #1 (permalink)
Canyon Killer
View ekopel's Photo Gallery
What does everyone think of deleting the EGR. Will there be performance gains? Will there be a gas mileage decrease/increase? Will it throw CELs? I know on other motors it is considered a performance modification, and I know it will not pass emissions, but I don't have to do emissions testing (know a smog tech).
Motor: 1MZFE, but im assuming will have the same effect on other motors.
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 01-05-2009, 12:39 AM   #2 (permalink)
engineer in training
Gameroom cash: $145055
The newer 1mz don;t have an egr as the engine is rated as a low emission engine. I confess I don;t know which years or anything more than not all 1mzs come with egr.
As for performance you wont see any gains, the ecu closes the egr valve when the throttle position sensor registers wide open. EGR is useful during part throttle operation and constant speed/throttle cruising.
I wouldn't delete it unless your intake is particularly filthy from it, but the 1mz runs a lot cleaner than some of the older engines like the 3vz and older 5s-fes.
It will throw a cel without some way to make the computer think the egr is still functioning.
Old 01-05-2009, 04:24 AM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
i think you should delete it...and then send me your functioning EGR valve.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-05-2009, 04:28 AM   #4 (permalink)
Canyon Killer
lol, you need one?
Old 01-05-2009, 12:32 PM   #5 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
AH HAHHAHA!
Many people remove it. I removed mine. King removed his. ^ on the Gen 3 is removed. Several on SolaraGuy have removed it.
5 Lug Corolla WHAT?
Old 01-05-2009, 01:27 PM   #6 (permalink)
Canyon Killer
im getting confused.
Old 01-05-2009, 03:55 PM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
alot of the guys i know of that have deleted it are FIed, its another roadblock easily gotten out of the way by removing it. i cant see how, na, it will really increase hp...at least not enough to warrant taking it off. IIRC, all it does is recycle some inert gas into the intake system to reduce emissions. and yes i need one.
R.I.P.
Car Domain:
Old 01-05-2009, 08:55 PM   #8 (permalink)
View camry6's Photo Gallery
I have the 3vz-fe. I removed my EGR about 4 years ago. It improved the low end and mid acceleration, but mostly noticed better fuel mileage. An EGR valve allows some exhaust from the engine to be re-circulated into the intake, sure, it reduces NO2X in the exhaust gas, but think about it......It does for the engine, what putting a hose in your ass, farting, and sucking it in would do for you.....I think both could be happier without! XD
camry6 is offline   Reply With Quote
Old 01-05-2009, 09:05 PM   #9 (permalink)
Goal: More Boost!
View 1MZ-FZE's Photo Gallery
Does anyone know how to block off the EGR and not throw a CEL??
1MZ-FZE is offline   Reply With Quote
Old 01-05-2009, 09:28 PM   #10 (permalink)
3rd Generation
Originally Posted by 1MZ-FZE View Post
I was under the presumption that the EGR valve actually increases gas mileage??
EGR decreases gas mileage. Exhaust gas takes up some of the space in the combustion chamber, when the valve opens, that would normally be filled with clean air. this causes a lower efficient burn of the fuel by reducing oxygen content, lower oxygen content means lower combustion temps, lower combustion temps=less NO2X. It decreases overall efficiency of the engine. Remember, emission systems are in place to reduce overall negative impact on the environment, in the case of the EGR system-its main purpose is to reduce Nitrogen Dioxide in the exhaust, even at the sacrifice of a little more fuel in the process.
Old 01-05-2009, 10:26 PM   #11 (permalink)
Canyon Killer
so, on the 1mz...??? keep it as long as im not FIed? P.S. Motor is out of the car, so its not like I would be doing work to remove it, i would just block it off and be done.
Old 01-06-2009, 03:11 AM   #12 (permalink)
On gasoline engines EGR increases fuel economy during cruise situations, but only mildly so and removing it really wont hurt anything. The Japanese domestic engines never had EGR, it was only added for US operation so there are plenty out there without it.
Old 01-06-2009, 04:32 AM   #13 (permalink)
I HAS BOOST!!!
bigbird's Avatar
it makes a bigger differance on the 3vz then the 1mz motors ive seen. its not a big deal to remove...even with the engine in. its a simple block off plate and resistor to trick the car into thinking its fine. slights increase in millage and power or slightly cleaner car for old mother earth. the biggest this is that ya may have to replace it to pass emissions.
R.I.P.
Car Domain:
Old 01-06-2009, 08:08 AM   #14 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
I'm no tree hugging hippie, but I'm personally not a fan of removing EGR or Cats for performance increases considering the significant increase in emissions. But that's just me.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 01-06-2009, 12:11 PM   #15 (permalink)
w00! I drive a Camry
View CamBOT's Photo Gallery
Will there be any visible effects from removing the EGR? such as increased tail smoke etc?
My car is an 92, i'm up for an emissions test on February. According to Ontario (Canada) law cars that are over 18 year old do not require an emissions test.
So i'm going to get my emissions done and then try blocking the EGR!
CamBOT
CamBOT is offline   Reply With Quote
