Engine swap for camry 93 v6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2009, 08:05 PM   #1 (permalink)
View micamry93v6's Photo Gallery
USA Engine swap for camry 93 v6
Hello Fellow memebers,
I am new to this forum. I own a 93 camry wagon v6 and love it. My engine just reached 175,000 miles and still powerfull and smooth but some issues are starting to show up such as ABS ligth coming on and check engine ligth the same thing. The car has a small oil leak but is botherfull because oil is dripping onto the exhaust pipe and is burning it causing fumes of burned oil.
I will try to get as much mileage out of this engine but I am thinking about an engine swap at arround 200,000 miles and need your advice. Is this a wise move? I also need advice on where to buy a used engine. Are those japanese imported used engines reliable and do they need some modifications? Thanks a lot.
Rick.
micamry93v6 is offline   Reply With Quote
Old 01-07-2009, 07:53 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Don't swap. Fix the leak. I guarantee you it's the oil filter adapter o-ring.
Look here
3vz-fe oil filter adapter
As for the Check Engine Light (also known as CEL), pull the code and find out what is causing it. Could be something as easy as an O2 sensor needing to be replaced.
You can do the same with the ABS light.
Definitely NOT a candidate for a swap.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
