How much miles?
If your changing struts too, might as well change springs at the same time, saves labor later.
You have plenty of routes on what kinda of suspension you want:
OEM: Toyota OEM parts of course
Cheap: Monroe Quick Struts
Comfort: KYB struts with springs of choice.
Sport: Tokico struts with springs of choice.
It's fairly easy to install, probably around 30-45 minutes per side, faster with two people.
Check sway bar end links at the same time, might need replacing of course.
Front strut mounts may need replacing, if you have the typical Gen4 front end clunking.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
