Bad CV Joints? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2009, 12:57 AM   #1 (permalink)
View 93'camry's Photo Gallery
3rd Generation Bad CV Joints?
Hey guys,
I used the search feature and found some info on my problem but just can't narrow it down.
93' Camry LE 2.2, 230,500 miles.
My car started shaking side to side while accelerating at about 45 mph. Once i let off the throttle it stops, same when coasting down hills. When the car is cold the problem isnt as noticeable but after about 10 min of driving it kicks in and vibrates the whole car when accelerating, hard to tell which side its coming from.
It would have to be part of the drive train because it only happens when accelerating correct?
So that eliminates needing a tire balance, bad wheel bearing, and bad rotors.
Thanks for any feedback in advance.
93'camry is offline   Reply With Quote
Old 01-08-2009, 01:33 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
Do you also feel a quick "thunk" and then the shaking?
Including a check of the cv joints, maybe you should see how the condition of your engine mounts are and get back with us.
Ontop of searching for those two things, here's a quicky:
CV:
Turn the wheel fully to one side and see if the boots are cracked. While you are turning a corner, do you hear clicking noises?
Mounts:
Sit in the car, hood open, engine on. Left foot firmly planted on the brake. Gentle rev with the right foot... Do you see it moving?
Either signs of trouble would make you do more diagnosis.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 01-08-2009, 06:03 PM   #3 (permalink)
Mounts:
Yes, the engine moves.
CV:
I do not hear clicking noise, and cant really tell if the boots are cracked, would it be leaking fluid if they were cracked?
Old 01-09-2009, 04:31 AM   #4 (permalink)
Chris Tacoma's Avatar
View Chris Tacoma's Photo Gallery
I'll be keeping a close eye on this thread Have the same exact symptom. Wife's car 00 Camry Le 4 cyl , checked for ripped boots , balanced tires , rotated tires , checked motor mounts , checked tie rods and ball joints , rotated tires , used spare to see if problem still there. It's annoying as heck and only under acceleration. Told wife I wanted to change drive axles and she said lets wait. I said OK , guess we can finally use that AAA membership we have if we break down
05 Tacoma access cab
Chris Tacoma is offline   Reply With Quote
Old 01-09-2009, 02:17 PM   #5 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
I just had this problem the other night. It was pretty bad, and it started while I was driving down the interstate in the rain at night. I was able to get the car back home and then took a different vehicle to buy a new (re-man) axle from O'Reilly for $59 and installed it the next morning. Just to warn you, the core charge is $75 (insane I know). After that experience I'd definitely say to not ignore this sort of a problem. I'm all about driving fast and on the edge but I have to admit that was a scary having to deal with. One of my boots was in really bad shape and the other was cracked a bit. Nasty grease/rain water poured out of one as I took it off. Needless to say they should've been fixed long ago. CV boots seem to be one of those maintenance items that are easy to forget about until they are too late. A boot is much cheaper and an axle if you can catch it early.
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 01-09-2009, 02:17 PM   #6 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
soooo, u have new BALANCED tires? and new bearings?
i have a bad bearing on the pass. side. it sounds really bad on the gas. very similar to what you just explained.
Originally Posted by 93'camry View Post
Hey guys,
Old 01-09-2009, 02:22 PM   #7 (permalink)
i dont think it would be leaking fluid..
turn wheel all the way left or right, get a light and check the boots... or reach in and feel the boots
Mounts:
Old 01-10-2009, 05:38 PM   #8 (permalink)
I checked out the boots and there are no cracks. I checked the boots closest to the wheel and also the next furthest from the wheel.
I just took the car for a drive and it went away
If i keep driving it could something worse happen?? I know its hard to say since we dont know what the problem is but worst case scenario...
Old 01-12-2009, 08:26 PM   #9 (permalink)
bump.. anyone?
Old 01-13-2009, 01:47 AM   #10 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Check your tie rod ends and ball joints.
If you had a bad wheel bearing, the noise would be constant and just get louder the faster you go. No bent wheels? Tires in good condition and inflated properly? Like mentioned above, your motor mounts may be the culprit. Checking the dogbone is easy but the front and rear ones take a bit more effort. You can jack up the engine and loosen or remove the mount to see if its broken or if they're really bad you can see where its broken.
Read here for more info. 5SFE Motor Mount How-to
96paseo is offline   Reply With Quote
Old 02-25-2009, 06:08 PM   #11 (permalink)
View toyodriver01's Photo Gallery
did you ever found out what the problem is?
starting to have the same problem, the wheel would wobble only when i apply gas but when i let off its smooth!
check the wheel looks good
checked around the tire nothings loose.
have a little hole on the cv joint on the outter boot
toyodriver01 is offline   Reply With Quote
Old 02-25-2009, 06:13 PM   #12 (permalink)
Ninja-rator
Sounds like definitely the cv joint for you my friend-- Hole in the boot is a dead giveaway. Run through the check list from above.
When you have a hole there, it usually means you don't know or remember how long it's been there. This means there is plenty of time for the grease to escape, runout, dry up, thus damaging the CV Joint. So is there a clicking when you turn right or left?
Old 02-25-2009, 06:25 PM   #13 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
What caught my attention is the side to side motion. Does this happen when, say. the car has the weight shift from one side to the other while accelerating?
This is what I recently was experiencing. Cause of this was the lateral control arm bushings being toast, in my case caused by my near collision I was able to avoid but spun out. Guess as I was spinning, it ruined them. After that, when I was more accelerating while the cars' weight shifted from one side to the other, I would get a side to side swaying motion. Initally when it happened, I thought it was the front end. Had an alignment and everything done, still no change. Had it rechecked and at that point found it was the control arm bushings being bad that was causing it. Replaced them all, and has been fine ever since.
Not sure if this is what is happening or not, but definitely worth checking out.
cykaaro is offline   Reply With Quote
Old 02-26-2009, 12:43 AM   #14 (permalink)
well i hear no clicking.
but when i stick my finger in the hole i can feel the grease in there, seems to be alot but how much is suppose to be in there?
it only happens when i apply the gas.it feels like the wheel would fly off!
Old 02-26-2009, 11:09 AM   #15 (permalink)
Hey Guys,
Sorry i forgot to post after my problem was solved.. It was the CV joints and I had to have both of them replaced because it couldn't be narrowed down to which side it was coming from. Only cost me $250 from a local guy which wasnt bad since Tires Plus quoted me at about double that. Thanks for everyone's help!
