Oil Leak 1995 Camry LE 4Cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2009, 02:13 PM   #1 (permalink)
View ConeyIslandFrank's Photo Gallery
USA Oil Leak 1995 Camry LE 4Cyl
Hi,
I've got a 95 Camry LE as my daily driver.
Oil seams to drip from below the right side of the engine.
You can see it along the inside of the passenger wheel well where the stabilizer link and cv joint is.
The car has 205,000 miles on it, with the leak being its only issue I would like to identify the source.
Thanks!
ConeyIslandFrank is offline   Reply With Quote
Old 01-09-2009, 02:47 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i would clean the engine first
Old 01-09-2009, 06:16 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check for leakage with engine running.
On the right side common areas of leaks are camshaft, crank and oil pump seal. If oil pump the leak can greatly increase when the engine is running.
Remove the tire and determine if the leak is coming from under the timing belt cover.
