Front end noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2009, 03:20 PM   #1 (permalink)
View GtariSSt's Photo Gallery
3rd Generation Front end noise
Ok, so I 've got a noise in the front end that is getting worse. Kind of a knocking noise that seems to be coming from the drivers wheel/suspension/axle area. It's worse if the wheel is turned slightly to the left. If I turn the wheel slightly to the right, the noise disappears. Once I bounce off the curb, however, I am stuck once again turning the wheel to the left and the noise is back. Ideas? CV joint maybe?
GtariSSt is offline   Reply With Quote
Old 01-09-2009, 06:11 PM   #2 (permalink)
View toyomoho's Photo Gallery
Make 90 and 180 degree turns each direction and listen for a clicking/popping noise. This is a sign of a bad CV joint. The bad joint is usually on the opposite side of the direction of turn.
Old 01-09-2009, 06:26 PM   #3 (permalink)
Proud Camry owner.
Loganwiththe'93's Avatar
View Loganwiththe'93's Photo Gallery
Sounds like a bad CV joint to me. If it's not the CV, maybe the tie rods or bushings. Just throwing things out there.
1993 Toyota Camry LE 4 Cylinder
Running 100%
Loganwiththe'93 is offline   Reply With Quote
Old 01-10-2009, 10:33 AM   #4 (permalink)
When I did the brakes a couple months ago (it had the noise then, not as bad) I tried to check for suspension play in the front end and couldn't find any evidence of it.
Old 01-10-2009, 10:53 AM   #5 (permalink)
View gonesurfing's Photo Gallery
Also, check the front swaybar bushings. Mine exhibited a similar noise that worsened when the wheel when turned one way.
gonesurfing is offline   Reply With Quote
Old 01-12-2009, 11:36 AM   #6 (permalink)
Thanks, I'll check that out.
Old 01-12-2009, 01:16 PM   #7 (permalink)
w00! I drive a Camry
View CamBOT's Photo Gallery
Same thing happened to me.
Turned out to be a busted CV boot and busted axel
CamBOT
CamBOT is offline   Reply With Quote
Old 01-13-2009, 11:35 AM   #8 (permalink)
When I make the sharp turns, though, I don't get the clicking/popping???
Just when I am rolling down the road, most noticable around 40-45 mph.
Old 01-14-2009, 03:11 AM   #9 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Tighen the front strut mounts, the big bolts on top of the strut from under the hood.
Get under the car with it jacked up from the front and try to shake the front sway bar, see if you hear a clunk. Otherwise, maybe try to lubricate the front sway bar bushings with some white lithium grease.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 02-13-2012, 09:40 PM   #10 (permalink)
View shovelhead's Photo Gallery
clunking noise on 98 camry
I have a 98 camry that has had the clunking noise for a year. Started with changing struts with little change in noise. Next, I changed the bushings in the lower control arm on passengers side. Still no change with noise. Found a website that suggested replacing upper strut mounts. I had checked them while changing the struts and they looked OK. I changed the mount on the passenger side first and the noise was gone. I changed the drivers side a few days later and the clunking noise is gone completely. I found these parts on the internet for about 33 dollars each, "borrowed" the compressing clamps from a parts store and changed them in less than an hour. Not too complicated, just pay attention to the position of all the parts as you disassemble the strut.
shovelhead is offline   Reply With Quote
Old 02-16-2012, 09:49 AM   #11 (permalink)
valiant1's Avatar
View valiant1's Photo Gallery
I constantly hear shaking sounds from the front of the car. I've had the car a year now and just recently changed my struts, all four. The sound is still there and has always been there since I got the car. My mechanic recently told me that I put on my struts wrong. Could this be the strut mount problem? Its such an annoying clunking, shaking sound, like something is loose on the suspension.
valiant1 is offline   Reply With Quote
Old 02-16-2012, 10:17 AM   #12 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
It could be strut mounts. When you replaced the struts, did you re-use the old mounts?
It's also highly possible it's the sway bar bushings or the sway bar links.
BMR is offline   Reply With Quote
Old 02-16-2012, 11:15 AM   #13 (permalink)
valiant1's Avatar
No, sorry, I went the cheap route and kept the old ones! But I will change them tomorrow when I change my springs and lower the car. I changed the sway bar bushings thinking that was the issue..it wasn't. But now they need to be greased as well because they're squeeking when I turn.
Old 02-17-2012, 04:45 AM   #14 (permalink)
