axle problem! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2009, 05:24 PM   #1 (permalink)
View jscollins's Photo Gallery
axle problem!
i need to know the best ways to get the passenger side axles out so i can finish this tranns swap all thats holding to old one in is that axel.please tell me how to get it out ive tried everything. i have no way to get the car moved and no air tools soo tell me before i have to junk the car(i only got 1 more week its a 1995 toyota camry coupe le automatic
jscollins is offline   Reply With Quote
Old 01-09-2009, 07:18 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Do a search and get out your swearing jar. Common problem asked many times. If you can't get it out call me, I'll buy the car from you if that's all that's wrong.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-09-2009, 08:08 PM   #3 (permalink)
View toyomoho's Photo Gallery
Have you removed the axle carrier bearing retaining bolt and circlip?
If so the bearing is most likely frozen in the housing. You best bet may be to unbolt the housing and remove it along with the bearing/axle. Then work on it at the bench or have a shop remove the bearing. It is most likely rusted in place.
Folks in the past have used a torch to heat the housing, penetrating fluid, LARGE hammer to bang the axle out.
As Stillrunning states this is a common issue, a TN search should turn up more suggestions.
Old 01-10-2009, 10:57 AM   #4 (permalink)
View gonesurfing's Photo Gallery
I cant remember the order, but I had to pry the CV shaft out of the transaxle with a crowbar, as well as tap the hub end out of the bearing. I used a large brass drift and a 4lb sledge hammer. As Toyomoho said, make sure the retaining ring is out of the bearing carrier.
It was a pain.
gonesurfing is offline   Reply With Quote
Old 01-10-2009, 03:02 PM   #5 (permalink)
i got the axle out and the tranns is dropped
Old 01-10-2009, 04:41 PM   #6 (permalink)
Great!
When you reinstall the axle bearing put some anti-seize compound in the housing.
