Cylinder Misfire Engine Code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2009, 08:42 PM   #1 (permalink)
View McCES's Photo Gallery
How common is a bad coil as the cause for a #1 cylinder misfire trouble code on a 2000 Camry 2.2L 5SFE? The #1 plug is black while the other 3 are gray so I'm guessing either coil or plug wire. The #1 and #4 cylinders share a coil. Can one half go bad without effecting the other? Is there a resistance test I can run to determine if it is a bad coil?
McCES is offline   Reply With Quote
Old 01-10-2009, 11:37 PM   #2 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $490868
View prnc_chrmng's Photo Gallery
Just changing the spark plugs on my girls 5s g4 fixed that problem on her car
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 01-11-2009, 08:55 AM   #3 (permalink)
I changed the plugs but that didn't fix it. I'm thinking can't be many more things other than wire, coil, or engine control module..........
Old 01-11-2009, 03:05 PM   #4 (permalink)
Needs more TRD...
2unknown's Avatar
View 2unknown's Photo Gallery
4th Generation
When my car had a misfire code, one of my fuel injectors was not operating.
Is there more than one code?
2unknown is offline   Reply With Quote
Old 01-11-2009, 04:30 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Yes, this can happen. Before assuming its the coil or plug wire, you should check the fuel injector. Take an ohm meter and measure the resistance of the injector on cyl. #1, then measure one of the other cylinders and compare the reading. If the injector reads the same or close to the other, your coil is bad. If you read on open(no resistance) or short(0 ohms), your injector is bad. You can read the resistance of the primary and secondary of the coil, but its not the best testing method.
96paseo is offline   Reply With Quote
