If one wishes to split hairs, then yes, technically, it is better to use distilled water. In the REAL world, however, it will never make any difference - so just use tap water and don't worry about it. Or, you could purchase the already-mixed (50/50) coolant - which is what I do. As someone else mentioned, a complete drain and flush is a PITA. Draining the radiator is easy. However, to drain the engine block, there is a drain plug on the back side of the engine, which can only be reached from underneath. What usually ends happening is that you spill lots of coolant when pulling this plug - or get a face full of it. Many people will drain the radiator, then try to flush the system with a hose - without removing the engine drain plug. So, they end up with the engine block full of plain water, as the engine block can't be drained this way, and which dilutes the new coolant mixture they put in the radiator. Do NOT do this - it is a recipe for corrosion in the system. I use a "hybrid" system, so to speak, like one of the other posters. I drain the radiator, about once a year - which removes about 1/2 of the total coolant in the system. Then, I refill with proper 50/50 mix. Since I do this about twice as often as the book recommends, the coolant never has a chance to get old and ineffective. The "old" coolant left in the system (since I only drain and replace about 1/2 of the total)...mixed with the new stuff....will be removed and replaced approximately on schedule (that is, about every 2 or 3 times I do the service). This procedure is MUCH quicker and easier (and less messy) than a full flush/ replacement, works just as well at the end of the day (as long as the coolant already in the system is not old and neglected)....and costs nothing, except for the cost of the replacement coolant. There is NO possible harm in doing it this way, as long as you are starting with coolant in good condition.
As for the thermostat - there is no reason to replace it, if it is not malfunctioning - that is just a waste of time and money.
