New Camry owner, window does not work
Just picked up my '98 Camry LE, and the only thing I could find mechanically wrong with the car is that the driver's side window does not work. The switch can operate all the other windows, but when I push or pull the button for the driver''s side front window, I don't even hear a clicking noise or anything.
Where should I start? I''m assuming this is not a motor problem since it would be going very slow...could it be the switch, or a relay?
I noticed the lights slightly dim when any other window switch is pressed, but nothing happens when I press that one button. This leads me to believe it's a wiring or switch issue. Thoughts?
Thanks
