bled brakes... still not stopping good - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2009, 02:13 AM   #1 (permalink)
Tech In Training
View Gun5's Photo Gallery
Well both the rear slaves where leaking so i replaced them... bled the brake on all 4 corners 6-7 times the car stops but not good enough... do I have to tighten the rear drums??
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
Old 01-13-2009, 02:27 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862010
View BamZipPow's Photo Gallery
What method were you using to bleed? Gravity? Vacuum? 2 person? Bleeder jar?
Are you sure yer master is still good?
BamZipPow is online now   Reply With Quote
Old 01-13-2009, 06:04 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
You need to reduce the travel of the shoes by adjusting them closer to the drum. Do that first then see how the brakes are.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-13-2009, 12:09 PM   #4 (permalink)
Tech In Training
did the rear pass then rear driver, front pass and front driver...
the brakes where fine before the slaves where leaking... do the rear drums have an adjustment from the back?? I didnt notice one
Old 01-13-2009, 01:51 PM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
You can get the adj sprocket from the large hole in the drum with wheel off.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-13-2009, 04:38 PM   #6 (permalink)
View djb2's Photo Gallery
The rear drum brakes are self adjusting. The adjustment happens when the parking brake lever is pulled -- the adjuster ratchets as the shoes are spread from the bottom. Sometimes it helps to set the parking brake while slowly moving backwards.
The rear disk brakes operate a little differently. They have small drum brakes only for the parking brake. Since wear isn't expected, these are manually adjusted at installation. The adjuster is turned so that the brakes bind up, and then loosened 4-8 clicks -- enough to let the wheel turn freely, with a little slack to handle thermal contraction. After both wheels are adjusted, the final adjustment is done at the operating lever so that handle engages 5-8 clicks with a 40 pound pull.
djb2 is offline   Reply With Quote
Old 01-19-2009, 11:29 AM   #7 (permalink)
View PtypE's Photo Gallery
Sounds just like my car a few days ago, I had to replace the master cylinder, the seal on the piston in the master cylinder had a small hole in it, just enough to allow the seal to fail, the brake pedal would travel to the floor before any braking force
PtypE is offline   Reply With Quote
Old 02-10-2009, 05:51 PM   #8 (permalink)
View FishyMan's Photo Gallery
thats freaking scary..
these camrys have crappy braking. even w/ new pads/rotors. i didn't see too much of a difference, granted they threw in some dumb drums on the rear. but even so. it sucks !
FishyMan is offline   Reply With Quote
