Camry Makes Grinding noise at cold start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2009, 08:59 AM   #1 (permalink)
View atoth22's Photo Gallery
I have a 1994 4 cylinder Camry with 135,000 miles. On cold mornings, the car makes a terrible grinding noise when I turn the key before it starts. It makes the noise for about a second and then turns over normally. It has never failed to start, but I fear one morning the car not starting. If I drive to the store, when I get back in the car, it won't make the sound since the engine is warmed up (I assume). I am curious what is going on, if I need to fix it, and how much it would cost to fix. Thank you very much.
atoth22 is offline   Reply With Quote
Old 01-13-2009, 09:04 AM   #2 (permalink)
just a nobody
My guess would be the starter drive; however, that is just a guess. It is possible that it is sticking when it is cold.
N.E.O.
Old 01-13-2009, 02:08 PM   #3 (permalink)
Proud Camry owner.
Loganwiththe'93's Avatar
View Loganwiththe'93's Photo Gallery
My car usually does this as well. I think it's pretty normal.
1993 Toyota Camry LE 4 Cylinder
Running 100%
Loganwiththe'93 is offline   Reply With Quote
Old 01-13-2009, 05:52 PM   #4 (permalink)
iratoyota's Avatar
View iratoyota's Photo Gallery
3rd Generation
Here is my post but i only got 1 reply-
In the morning my car does not start on the 1st crank....It makes a god awful loud kinda grinding noise. It turns over cleanly on the 2nd turn always.
At 1st it was intermittent at once a week now it is 3-4 times a week. It's happens on the colder mornings. What is this problem ?
Could be the starter gear not fully engaging the flywheel gear, or a worn starter gear. I'd pull the starter and check the condition of the gear and the flywheel gear as well. You can turn the flywheel with a large screwdriver to inspect all the teeth. Remove the plugs first.
iratoyota is offline   Reply With Quote
