2000 Camry Idling Hot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2009, 11:33 PM   #1 (permalink)
View tdla's Photo Gallery
Question 2000 Camry Idling Hot
My 2000 camry 4 cylinder coolant temp gauge will read pretty high (3/4 of max) when vehicle is allowed to idle for very long. Yesterday it was doing this at 40 degrees F ambient. If I rev the engine up to a steady 1500 rpm or so, the coolant temp immediately begins to return to normal. Same thing if I put it in gear and drive away. Any ideas, anyone?
Tony
tdla is offline   Reply With Quote
Old 01-15-2009, 12:12 AM   #2 (permalink)
View my name is joe's Photo Gallery
i just fixed this problem today. is the fan behind the radiator working? it should turn on and off by itself once in a while when the engine is too hot. check your coolant and everything that goes to the radiator(pipes, tubes)
my name is joe is offline   Reply With Quote
Old 01-15-2009, 01:54 AM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862010
View BamZipPow's Photo Gallery
Sounds like yer coolant might be low.
BamZipPow is online now   Reply With Quote
Old 01-15-2009, 02:46 AM   #4 (permalink)
pro nub
View trdcamry00's Photo Gallery
Check to see if your thermostat is working and if your fans turn on. If it overheats on you while you're driving turn up the heater.
trdcamry00 is offline   Reply With Quote
Old 01-15-2009, 07:26 AM   #5 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $303505
View MrSo0h0o's Photo Gallery
This may also be caused by a crack in your radiator. Check for coolant leaks or any possible failure spot on your radiator.
MrSo0h0o is offline   Reply With Quote
Old 01-15-2009, 11:39 AM   #6 (permalink)
I forgot to mention that the coolant level is good.
If the radiator fan were the problem, then I can't see how revving the engine while the vehicle is stationary would make the coolant temp come back down, as the fan is thermostatically controlled/electric.
There is no coolant leak anywhere. I'm am beginning to wonder if perhaps the water pump has a bad impeller, i.e. missing a blade or blades. Has anyone see this happen before?
Tony
Old 01-25-2009, 06:53 PM   #7 (permalink)
my problem was that the switch. not sure which one. was broken. check your fuses too. i dont think it would be the problem. bring it to a mechanic if anything.
