98 2.2 timing belt trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2009, 11:50 PM   #1 (permalink)
View jase90's Photo Gallery
I Have a 98, 2.2 camry and the water pump failed on the freeway last week so lost the timing i got the car home, and changed the water pump and the timing belt, but it just cranks over and will not start, is this an interference engine???? any help be appreciated.
jase90 is offline   Reply With Quote
Old 01-14-2009, 11:57 PM   #2 (permalink)
just a nobody
Did you time it properly? Have you check to make sure that the cam and crank sensors are not damaged?
BTW, it is not an interference engine.
N.E.O.
Old 01-15-2009, 01:00 AM   #3 (permalink)
yes i think i timed it properly, the crank was at tdc on the mark on the cover, and the cam was with the little point to the mark on the back plate( not the big timing trigger!) the belt had not completely shreded just lost about a 1/4 to 1/2 inch of its width, the wife was driving at the time so i cant say exactly what happened, any way i checked the timing again to make sure it was correct and it apperared to be, as for the sensor they were not struck by anything, and looked ok, what is the resistance to check for on them??
Old 01-15-2009, 01:09 AM   #4 (permalink)
just a nobody
Just in case, here is something for checking the timing belt alignment: http://www.camrystuff.com/manuals/Ge...hanical_I4.pdf, page 27. And for checking the cam and crank sensors: http://www.camrystuff.com/manuals/Gen4/Ignition.pdf
N.E.O.
