replacing seals on 93 I4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2009, 01:29 PM   #1 (permalink)
View wally748's Photo Gallery
Smile replacing seals on 93 I4
hello, im new here and have a ? on my 93 camry w/ 118k i bought it new.timing belt has been replaced oil change every 3 or 4 k. just had oil pan gasket replaced by dealer he told me all front seals were also leaking and gave me a price it sounds a bit high to me but not sure maybe someone out there can help .valve cover gasket 208.62-dist.seal 54.12-oil pump seal 126.25-crank&cam seals126.25. also wants 181.00 for hood struts told him i wont even consider that.
thank you much
wally oh i live in eastern pa. near phila. also my camry came from japan are they any different than usa makes?
wally748 is offline   Reply With Quote
Old 01-15-2009, 01:40 PM   #2 (permalink)
View toyomoho's Photo Gallery
When was the belt last changed? Changing the cam, crank and oil pump seals requires removing all of the parts needed to replace the belt.
Are you at all hande with tools? Valve cover gasket is too high, you can do this job yourself.
Hood struts as is in holding up the hood?
Old 01-15-2009, 01:53 PM   #3 (permalink)
[quote=toyomoho;2630490]When was the belt last changed? Changing the cam, crank and oil pump seals requires removing all of the parts needed to replace the belt.
Hood struts as is in holding up the hood?[/quote yes
the belt was replaced at 90 or 94k. i want to do the valve cover my self but dont know if i should have the other stuff done first or last. thank u for responding!!
Old 01-15-2009, 02:12 PM   #4 (permalink)
View djb2's Photo Gallery
The front seals themselves are pretty inexpensive, especially if you buy them online.
Rockauto.com has a set of them for under $10, although the shipping can double that. You might get to free shipping from a different source if you are buying more parts.
Hood gas springs are available from local parts stores, perhaps for a lower total with the shipping cost when ordering online. (Unless you use them as "fillers" to reach the free shipping minimum.)
Putting them on requires removing the timing belt. It sounds as if you just paid for a timing belt job, so that might be annoying. If you are willing to do the work yourself, allow a whole evening and have a back-up plan if you need to run out for an extra tool.
djb2 is offline   Reply With Quote
Old 01-15-2009, 02:20 PM   #5 (permalink)
How bad are the leaks?
The dist housing seal and valve cover leaks tends to be small.
The cam and cranks seals not too bad. The oil pump seal can leak a LOT of oil via a steady drip when the engine is running. If you can, remove the passenger tire, start the engine and look for oil dripping out from under the lower timing belt cover.
Check your oil level daily as if a bad oil pump seal can leak a Lot. It can be a steady drip when the engine is running.
Visit the AutoZone website and look into their vehicle repair guides about working on the various items or purchase a low cost Haynes shop manual.
Replacing all the parts is not too hard but would be time consuming even more if doing the job the first time.
Old 01-15-2009, 02:52 PM   #6 (permalink)
Wink
the dealer also did the belt not the one that gave me the prices. at the time i dont think i had any leaks if i did i didnt notice any it was about 6mos later and has gradually gotten wrose thanks again for your help
Old 01-15-2009, 03:09 PM   #7 (permalink)
i dont think i will try this myself other than the valve cover, hood struts &dist when should i do the valve cover befor the other seals or after. thanks for all your help
Old 01-15-2009, 06:12 PM   #8 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Prices are REDICULOUS. Do it yourself. MUCH cheaper.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
