As most of you know, i have and HID projector retrofit on my car. A couple of weeks ago my passenger side went out, i thought it was the bulb changed, still no good. I checked the headlight fuse under the hood, fuse it fine. I was at a stump. So today i decided to check the wiring of the Retrofit itself...everything was fine. So what i decided to do was to directly connect the H4 bulb that is suppose to be there directly to the OEM stock of the car adn to my suprise the bulb didnt turn on, aka LOW BEAM was messed up on the passenger side. I flicked on the HIGH BEAM adn the bulb came on
So i tried the DRLs...my driver side project came on but the passenger side with the H4 bulb connected to the socket was off...What can possibly be wrong?
Here is the diagram of my HID setup
ALL FUSES ARE FINE
