Idle Overheating but ok with A/C running? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2009, 08:01 AM   #1 (permalink)
View 94CamryMan's Photo Gallery
So when I'm idling my engine starts to overheat. But if I flip the A/C on and set the fans to high and blow hot air, the radiator fans come on and cool it back down to operating temperature. Any ideas what could be causing this? Thanks.
94CamryMan is offline   Reply With Quote
Old 01-16-2009, 08:05 AM   #2 (permalink)
just a nobody
Check the coolant fan switch if the radiator fan don't come on by themselves.
N.E.O.
Old 01-16-2009, 08:08 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Sounds like engine cooling fan is not activating. Test fan by disconnecting fan switch on lower rad hose (engine off first), fan should come on with switch disconnected. If not switch then possibly relay.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-16-2009, 08:11 AM   #4 (permalink)
Yes the fans come on when I disconnect the coolant fan switch.
Old 01-16-2009, 08:14 AM   #5 (permalink)
just a nobody
Probably a bad switch, it there is sufficient coolant flow to the switch.
N.E.O.
Old 01-16-2009, 08:19 AM   #6 (permalink)
I would assume there is only because when I turn the A/C on the engine cools down. But I'm not positive that's proof of good coolant flow.
Old 01-16-2009, 08:52 AM   #7 (permalink)
Woo Hoo!!
sbushnak's Avatar
Gameroom cash: $173010
View sbushnak's Photo Gallery
What year and engine do you have?
I had the same problem in my 97 5sfe. I checked the switch, sensor and relays and all tested good. I changed the thermostat and it fixed the problem.
I only drove about a 1000 miles and so far so good.
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline   Reply With Quote
Old 01-16-2009, 09:16 AM   #8 (permalink)
So fan does not come on when engine temp climbs at idle? No overheat at speed? Test resistance of switch. Could be bad rad. Not sure if it's stat as engine cools when A/C on. Seems sticking stat would cause overheat but fan would also work.
Old 01-16-2009, 09:10 PM   #9 (permalink)
I tested my cooling fan relay today and I'm getting continuity between contacts 3 and 4 but apparently no continuity between 1 and 2. On my multimeter it read about 730 and I was getting no sound. So I guess this narrows it down to my relay? If so can a relay be fixed or is it better to just shell out the $50 and buy a new one?
Old 01-16-2009, 09:39 PM   #10 (permalink)
just a nobody
If the fans come on with the A/C or when you disconnect the fan switch, it sounds like your relays are working. Which relay did you test, there are three different ones for your car.
Here is the wiring diagram link for your car: http://www.camrystuff.com/manuals/Ge...ry94wiring.pdf
N.E.O.
