Rubber burning smell when idling with defrost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2009, 02:38 PM   #1 (permalink)
View stockcammy's Photo Gallery
4th Generation Rubber burning smell when idling with defrost
I have noticed a rubber burning smell while I idle and have the defrost on. Every now and then, I hear a belt squeel or will see smoke coming from the right side of the hood. The auto repair shop says it is my heating core. Anyone have any input or info? I seem to think it is just a belt.
Thanks
stockcammy is offline   Reply With Quote
Old 01-17-2009, 03:37 PM   #2 (permalink)
View davemac2's Photo Gallery
you don't mention the year of your vehicle. If the A/C is coming on in defrost mode, it may be the A/C compressor is siezing and causing the serpentine belt to slip/burn? Open the hood and check it.
dave mc
davemac2 is offline   Reply With Quote
Old 01-17-2009, 04:59 PM   #3 (permalink)
Sorry. It's a 2000 XLE V6. What can be done to fix this problem if that what it is?
Old 01-17-2009, 06:13 PM   #4 (permalink)
View toyomoho's Photo Gallery
Find the AC compressor, should look like the photo below:
http://info.rockauto.com/Denso/Detai...p/471-0312.jpg
When the problem returns watch and listen at the pulley area.
Old 01-17-2009, 11:39 PM   #5 (permalink)
if that is what it is, you will need a new a/c compressor probably. $$$ unfortunately. it might be a slipping a/c clutch though too. who knows. To get rid of the burning smell for now, you can maybe remove the a/c fuse. That would at least confirm or disqualify the a/c as the source.
dave mc
Old 01-18-2009, 07:04 AM   #6 (permalink)
View dorman68's Photo Gallery
Sounds like an ac compressor about to seize or partially seized. I would unplug the connector to the compressor clutch and see if the sound and smell goes away.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
