Distributor o ring fix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2009, 04:57 PM   #1 (permalink)
View caveboy's Photo Gallery
I have a 95 camry with slow but chronic leak after resealing valve cover serveral times thinking it was the cause I paid more attention to the oring and read up they are problematic ..so I tried this seal from the back side with blue silicone..hope it works. the leak is slow but keeps you on your toes if try to keep that drive way clean and save some on oil top offs...
http://picasaweb.google.com/therealc...00362543869298
hope this helps o may want to give me a few days to make sure it works
caveboy is offline   Reply With Quote
Old 01-17-2009, 06:21 PM   #2 (permalink)
View toyomoho's Photo Gallery
The dist has an O-ring around the body that slides into the cylinder head, have you replaced this?
If this is the problem remove the sealant to keep it from getting into the engines oil system.
Old 01-17-2009, 06:53 PM   #3 (permalink)
oring
yea thanks this is #3 oring.. the OEM is bit small someone else said get aftermarket
Old 01-17-2009, 07:26 PM   #4 (permalink)
Are you sure the oil is from the body O-ring and not the dist shaft. The dist shaft can leak between the shaft and housing.
With the dist out did you clean the bore in the cylinder of any debris? The O-ring would be metric but nothing special. A well stocked auto parts or hardware store may have one that is larger in cross section.
If you can mark the exact location of the dist adjustment when installed, clean every thing up to remove the oil then apply high temp silicone seal or form in place gasket material to the dist housing when reinstalling it. Install the dist in the exact location so you do not need to move it for timing. Let the seal cure over night before starting.
Old 01-17-2009, 07:55 PM   #5 (permalink)
okay will try that next if this does not work..thx
Old 01-19-2009, 08:55 AM   #6 (permalink)
View proftomda's Photo Gallery
USA
Thats alot of silicone. I would try to clean up the excess to ensure it doesnt break free and migrate thru your oil system. The distributor shaft o ring that needs to be replaced only costs a couple bucks and doesnt require any more work that what you have performed.
proftomda is offline   Reply With Quote
