V-LED's...problems??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2009, 08:32 PM   #1 (permalink)
View .Camryman97.'s Photo Gallery
4th Generation V-LED's...problems???
Has anyone had problems with LED's going out way before they should. I bought a pair of license plate LED's from them in July maybe August( cant remember) http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 here are the bulbs i got. They worked great and looked great too. After about a month one of them started blinking and after about a week or so it went out and occasionally it would blink every here and there. So I just said whatever. And just recently the other bulb went out as well so that got me a little angry because LED should last longer than halogens right??? So I was just wondering if anyone has had problems with these bulbs. Im going to send them an email seeing if i can get anything outta them.
I plan to get some of these ( im not sure if you can tell but theres led's wrapping around and one pointing down for a wide angle) from superbrightleds.com cause ive heard good things from them
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 01-18-2009, 09:37 PM   #2 (permalink)
shuluke's Avatar
View shuluke's Photo Gallery
I dont want to be a bringer of bad news, but if the leds are voltage regulated very well, that reduces the lifetime of the LEDS dramatically. Most LEDS should last ovre 100,000 hours if proper voltage and temp conditions are met. I am guessing the ones you have are not voltage regulated.
A cars voltage can go from 12.8 volts to 15 volts(with alternator running).. Thats a huge swing in terms of voltage. For example, If I had leds that needed 10 volts, and I was regulating 2~3 volts, its alot, but depending on how I am getting rid of the extra volts, it might not be too bad. But if my car was hitting 15 volts, 5 volt drop is alot for any regulator. If you can get rid of the heat, the regulator would be able to pull it off though. it seems from the picture you posted, if there is a regulator, its right next to the leds and leds and heat do not mix well.
Also if they were not regulated, the over voltage pushed the leds too much, and thats why they "died" prematurely.
I have some of the ones you suggested you wanted to pick up, and so far, I have not had any problems with them. Good luck.
Shuluke
1998 Camry (279,xxx miles)
2002 Camry LE (109,xxx miles)
2000 Solara (135,xxx miles) SOLD
2004 S2000 (98,xxx miles) Supercharged!
shuluke is offline   Reply With Quote
Old 01-18-2009, 10:24 PM   #3 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
send 'em back. they are really good about replacing them. i've ordered from them way too many times and i've had a few bad ones.
TheKevin is offline   Reply With Quote
Old 01-18-2009, 11:49 PM   #4 (permalink)
i dont know if ill send them back but ill see ill send them an email get some new ones
and if i get an email back to send them in and get some new ones... then ill do that so ill have extras
Old 01-19-2009, 09:39 AM   #5 (permalink)
on full afterburner
Gameroom cash: $1339397
They replaced a defective bulb for me with no questions asked. Didn't have to send anything back.
Old 01-19-2009, 09:22 PM   #6 (permalink)
well they emailed me back and they said they'll ship some with no problems
they told me they had a batch that went bad
Old 01-20-2009, 12:03 AM   #7 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Thats good to hear. I bought some SMT LEDs that went prematurely and they replaced it. No questions asked!
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
