hello guys well first of all i am new here and to Toyota,,, i just recently purchased a 94 toyota camry 4cyl. and the car ran fine for 1 day,, after that the second day i was washing the car and all of a sudden it died on me! god i was so disappointed, well i didnt want to hijack no ones thread so decided to start my own,, similar to some of the other threads
i have no power to the fuel pump.. tested the pump with direct power from battery and works fine,, i also have no spark either,, so based on what i read from the other threads i replaced the efi relay, checked the starter relay and works just fine,, i did have the issue with the car blowing my am2 fuse repedeately, so i eliminated the resistor inside the distributor like someone in this forum said.. and that fixed the problem with that fuse.. so now i also have power in the 7.5 ign fuze that i didnt before.. i also replaced the coil inside the distributor along with the distributor housing. and still nothing..
i also replaced the ingniter which also mentioned here could be the problem.
no surprise still nothing!! so now i got about $400 dollars in to the car and still cant make it run...
so just to recap to you guys.
replace efi and starter relays. replaced coil ingnition and distributor housing along with the igniter. and still nothing!!!
also i have no spark at the wires. tested with a screwdriver at the wire..
car does turn over and cranks fine... car does seem to sputter a little when i add starting fluid in the air filer hose. but wont start..
my timing chain is fine...
any help would be greatly appreciated.
i can answer at any time. so if you have questions for me, i will get back to you asap..
i heard toyotas were really good cars. but after owning one for 1 day. im very much ready to give up on it. please help me fix my car and change my thought to good about toyotas.. no offense to any of you toyota lovers. im just having a real bad experience with one... please please help me turn this around!!!!
thanx much
