hey, i'm not sure about the mechanical changes from 95 to 2000, but you might want to read this. I had the same problem and fixed it by adding a shim as there was no factory shim to make up the difference.
Some will say I'm nuts and should have pulled the head, but the compression on the 162,000 mile engine was only off by 6lbs per cylinder so I left the head on and added my own shim to make up the differene.
Read this. . .
Who has Successfully Adjust Valve Lash 1MZ????
I'll try and restore the missing links and fix the missing pictures.
PS - It had 162,000 miles on it then. It has 206,000 miles on it now and all is well. I run the cr@p out of this little V6 and it
hasn't spit out the shim 0.4826mm (0.019") which I added under the factory #17 shim.
Measured: 0.31" (0.7874mm)
Spec is .014" (0.3556mm)
Difference: 0.017" (0.4318)
So I made a shim from 0.19" stock and added it under the existing shim.
Give it some thought and do some research on your engine. On the 95 1MZ the lifter bucket has suffcient depth to retain the factory shim while adding a 0.017" shim under it. I bought a lifter bucket from Toyo so I could measure it and fit my shim stock under it. This was very helpful. I'd recomend it so you get a good visual of what you intend to do. Well if your engine even allows this type of thing????
best of luck and I'll check back and see. (Although its been months since your post).
73Sport
