97 auto gear oil? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2009, 01:33 AM   #1 (permalink)
I SHOCK AMAZING!
View MA drigal's Photo Gallery
97 auto gear oil?
also, i have notice the D light when going on gear will not turn on green light...anyway of getting the green light back on?
MA drigal is offline   Reply With Quote
Old 01-21-2009, 02:01 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Automatic=trans fluid. Manual=gear oil. Your trans will take Dexron/Mercon III trans fluid. Do not use gear oil!
96paseo is offline   Reply With Quote
Old 06-06-2009, 04:04 AM   #3 (permalink)
I SHOCK AMAZING!
How many quarts will i need?
Old 06-06-2009, 08:43 AM   #4 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
If your dropping the pan, about 2.5 quarts comes out. Get 3 just to be safe though.
carsrus is offline   Reply With Quote
Old 06-06-2009, 02:36 PM   #5 (permalink)
Gameroom cash: $303055
Your trans requires the use of auto trans fluid that complies to Dexron II or III specs. Today, most of the trans fluid that is available conforms to both Dexron and Mercon specs, as 96paseo pointed out. I thought I would mention this just in case you do find trans fluid that still conforms to one spec or the other, but not both.
Mike
Old 06-06-2009, 07:29 PM   #6 (permalink)
View flyeri's Photo Gallery
Removing pan or draining will take a little less than 2.5 qts to bring level back up to specs. Add 2 qts, run and add the additional fluid.
The differential is seperate and takes about 1.6 qts to drain and refill.
flyeri is offline   Reply With Quote
Old 06-07-2009, 03:27 AM   #7 (permalink)
I SHOCK AMAZING!
also, i need the green light for the D to turn own when i go on gear... mine not functioning... would i need to replace anything?
Old 06-07-2009, 03:14 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Bulb check in the dash instrument panel first.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
