Hi,
My 2000 Camry CE's air cleaner housing is loose. I push and pull the housing and it is movable. And I also find the accelerator cable close to this housing is tore by the edge of the housing. Seems like I need to solve this issue.
I want to take apart the housing and tight the bolts on the bottom of the housing. But there are not only the air intake hose but also a couple connectors attached to housing. The Haynes Repair manual says nothing about the connectors about how to detach those connector while removing the housing.
Any experience, suggestion or comments on removing this housing are appreciated.
