Vogtland Springs Instructions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2009, 03:54 PM   #1 (permalink)
View JamesT1's Photo Gallery
Does anyone have or know of a place online where I can find the intallation intructions for these springs? I have a few questions and can't find my copy.
Thanks
http://bespokeauto.blogspot
1996 Camry LE Sedan 1MZFE
JamesT1 is offline   Reply With Quote
Old 01-22-2009, 04:32 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
what are your questions.? IIRC theres nothing special about vogtlang springs that would warrant any special install. we should be able to help.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
bigbird is online now   Reply With Quote
Old 01-22-2009, 06:34 PM   #3 (permalink)
Well, I wanted to see if the rear springs are interchangeable (right to left) and if the bump stops need to be cut.
Old 01-22-2009, 07:07 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359260
iTrader Score: 13 reviews
how low is the drop? if it's around or over 1.5", then it's safest to cut them rather than risk bottoming them out. But the bump stops on the camry aren't that big either, so it shouldn't be a huge concern
as for spring interchangeability from left to right, unless they're designed differently from other springs, they will be.
HaHa
Old 01-22-2009, 08:48 PM   #5 (permalink)
I see. Thanks.
I was just curious because the rear passenger side seems higher than the rear driver's side; I thought maybe I had done something wrong somewhere.
Old 01-22-2009, 09:46 PM   #6 (permalink)
TN Pussy Man
did you seat the spring properly on the bottom perch?
HaHa
Old 01-22-2009, 09:58 PM   #7 (permalink)
I thought so...
...I'll double check it this weekend
Old 01-23-2009, 05:15 AM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
mine did the same thing, there was a slight list to it. never figured out why maby jsut bad bushings on the drivers side due to thre only being one person in the car for most of its life.
R.I.P.
Car Domain:
Old 01-23-2009, 08:12 AM   #9 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
If you just installed them, check to see they're all set properly on the perch in the bottom of the strut. Also ensure that the top of the struts are positioned properly in the strut tower.
Beyond that, it's likely they just need to settle in.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
