1995 Camry Electrical - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2009, 04:37 PM   #1 (permalink)
View DM37211's Photo Gallery
I just installed a new Battery in my 95 Camry. As soon as I connected it, the headlights came on even though the Switch is off. No response when i turn the key, not even a click. Any ideas?
DM37211 is offline   Reply With Quote
Old 01-23-2009, 05:05 PM   #2 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
check your fuses. did you by any chance cross terminals in the process of reinstalling the new battery or removing the old?
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 01-24-2009, 03:59 PM   #3 (permalink)
Gameroom cash: $303055
Does this car have an aftermarket alarm system? If so, locate the fuse for the aftermarket alarm system and pull it. Then see if the car starts. I have seen aftermarket alarm systems do strange things like this.
Mike
Old 01-27-2009, 07:32 AM   #4 (permalink)
1995 Camry electrical
I checked all fuses. Dome light was blown. Didn't cross terminals. Situation Same. Thanks for the suggestions.
Also no alarm system.
Old 02-24-2009, 11:19 AM   #5 (permalink)
TexanF250's Avatar
View TexanF250's Photo Gallery
Did you get this fixed? If so, what was the problem? I am having the exact same issue. I too changed the battery and when I did, the car began doing the exact same thing you described. The lights are on even with the light swtich off and I cannot get them to turn off. Mine is a 94 Camry.
TexanF250 is offline   Reply With Quote
