ABS code 38? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2009, 04:43 PM   #1 (permalink)
View Posimoto's Photo Gallery
ABS code 38?
I completed a diagnostic check on my 94 4 cyl ABS system and came up with a code 38. The two DTC charts I found on the forum are missing the code 38, one chart goes from 34-41 and the other from 37-41 (Possibly the wrong year or engine).
I also found a post where it was mentioned that ABS code 38 is an open circuit in the right rear sensor. Could someone confirm this please?
Thanks in advance.
Posimoto is offline   Reply With Quote
Old 01-25-2009, 05:30 PM   #2 (permalink)
View Dan2002's Photo Gallery
Yeah, I had the same code on my '96. I replaced the sensor and the code cleared, but I've heard there are ways to clean them up and get 'em to work again.
Dan2002 is offline   Reply With Quote
Old 01-25-2009, 06:58 PM   #3 (permalink)
just a nobody
You probably have a Bosch ABS system, that is where the code comes from. The other system is from Nippondenso, which doesn't have code 38.
N.E.O.
Old 01-26-2009, 06:56 PM   #4 (permalink)
Thanks guys!
I ordered 4 struts and should be in sometime this week after I install them I will tackle the right rear wheel sensor and post my results. Again, thanks!
