Smoke always! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2009, 04:18 PM   #1 (permalink)
View LUVLEXUS101's Photo Gallery
3rd Generation Smoke always!
Im just wondering is it normal that even after my car has fully warmed up, I still always see the exhaust gases, especially if i give it some gas. I have the 3vz-fe and i only get 13 mpg, im still trying to figure out why. A lot of other cars like my 02 sienna, the exhaust gases disappear after warming up completely.
Any ideas?
LUVLEXUS101 is offline   Reply With Quote
Old 01-25-2009, 05:32 PM   #2 (permalink)
Woo Hoo!!
sbushnak's Avatar
Gameroom cash: $173010
View sbushnak's Photo Gallery
What is the color of the smoke?
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline   Reply With Quote
Old 01-25-2009, 06:02 PM   #3 (permalink)
3rd Generation
I guess its kind of whitish - gray?
When its started at like 10 degrees is pretty damn white
Old 01-25-2009, 09:45 PM   #4 (permalink)
View Albuynp Ryeno's Photo Gallery
Depends on the weather. If you can always see the smoke, no matter the weather then yes something is wrong.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Old 01-25-2009, 09:54 PM   #5 (permalink)
Justin '93 Camry Owner
View AmericanAirFan's Photo Gallery
Yeah something is definitely not right. Mine occasionally smokes on start up due to some old seals, but after that it's smooth. Usually it only smokes on start up after the car has sat for a while (a day or more) allowing oil to collect. I have a 5 speed manual Camry, I'm not very easy on the gas and no matter how hard I try I can't get below 20 MPG when put putting around town. I've heard that having too much oil can cause your engine to not only become damaged if driven for long periods of time, but you will also get significantly low gas mileage.
Are you sure you don't have to much oil?
Also if it's a whitish grey most likely that is oil smoking out the exhaust...
AmericanAirFan is offline   Reply With Quote
Old 01-25-2009, 10:18 PM   #6 (permalink)
View camryvibe's Photo Gallery
All gasoline & diesel engines put out lots of water vapor (H2O and CO2 are the normal combustion products). Normally the exhaust is hot enough so the water vapor is invisible gas but when you first start the car, especially on cold days, it's visible as white fog as the water condenses. If yours remains visible longer than normal as the engine warms up there are a few possibilities:
1) your engine is running colder than normal (might be an open thermostat) - does the heater work well? How high does the temperature gauge read?
2) there's some variation between different engines and exhaust systems as to the temperature of the exhaust. If the smoke is just a little more than some other cars and is only visible on cold days then it could be normal.
3) there might be a coolant leak that's getting into the exhaust (typically from a faulty head gasket). Does your coolant level drop over time? Does your oil on the dipstick look at all milky or chocolate-colored?
camryvibe is offline   Reply With Quote
Old 01-26-2009, 04:12 AM   #7 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
An open thermostat should not make your car puff out white smoke. If the car has not been consuming coolant or large amounts of oil, I would suspect a fuel problem. If your comfortable pulling your spark plugs, do so and look for a plug that is gas fouled(black color and wet). This will help you isolate a particular cylinder. If more than one cylinder is gas fouled, you're problem is most likely sensor related. With that kind of mileage, I would suspect a bad injector or malfunctioning ECT. Injector and ECT testing is usually done with an ohm meter. Does your exhaust smell like a gas?
96paseo is offline   Reply With Quote
Old 01-26-2009, 08:26 AM   #8 (permalink)
3rd Generation
It consumes neither coolant or oil, but a lot of gas, and it warms up very nicely, stays dead on in the middle of hot and cold once fully warmed up, the heater works very well as well, I do think the exhaust smells like gas quite and bit and im only getting 13 mpg.
When would I need to pull the spark plug and check it?
Before or after driving or just starting?
Old 01-26-2009, 08:28 AM   #9 (permalink)
Oh no, I just realized you were also mentioning sensors and I have a code 55, which I think was knock sensor bank 1, argh, i hope that isnt it
